#1 2016-06-09 04:56
- rickygao
- Member
add support for "make this my main display"
Please add support to allow NetSetMan to switch "make this my main display" on different screens
#2 2016-06-09 09:28
Re: add support for "make this my main display"
We try to keep the amount of settings that are not directly network related as low as possible for not overloading the application. In one of the recent versions we've introduced the option to change the presentation mode (only internal display, only external display, clone display, extend display) because this is useful, when a laptop is moved to a conference room and attached to a projector. We don't see any related use case for your current suggestion. Please describe your use case (why you need to change this frequently).
